If the heater still works, no. But you need something to demist the front window. A/C or heater.
yeh this.
their excuse for this is that if the car is cold the heater wont demist the front window, making the removal of A/C ileagle.
best headlights have to go to Nissan President 6 gun projectors
this, awesome headlights
see the projectors in a cima once was tuff
Its been in there for about a year so im sure its dirty
have you removed the entire system? or is the pump/lines still there?
I would just tell the guy you got the diff reconditioned and it clunks because it is yet to wear in, at least that is what the diff place told you....
Mine has quietened down significantly since using the Penrite 80w140; only clunks when the diff is really warmed up. can always put anti-chatter in if I get sick of it, but I like the performance too much :)
Yeh I got a black one so it looks stock
I got Sunday off billy happy to help out
I ordered a black one but got this awesome metallic red one in the mail instead..
Even though nobody sees it I feel it would be a crime to paint over it..
yeh this.
i can defog my wimdscreen in 5 seconds by winding my window down so y should i need either
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
