the auto barn fire extinguisher comes with a bracket. just drill out the hole a bit (get a workshop to do it. if they wanna charge you for 30 secs of work go somewhere else) and bolt it to the rear seat tab. then screw the other end into the floor pan with a self tapper. its not gonna go anywhere.
blue and red contact from news agent = win. All of $5ea for a roll of 5M, that is a lot of triangles.
fire ext easy to do with a bit a metal from bunnings, plus something to cut it with and something to drill holes with.
What's the red triangle for? Says nothing in the sup reg about that. Only says blue triangle and tow stickers
got the stickers... NOW. for the extinguisher. lol. grant, i come to donny you do for me? i bring you a blow up doll.
Don't have drill or drill bit strong enough to drill metal...
But tafe do have them.
trackday at nationals alvin?
Hey Cass, odd I know but can you measure number plate brackets on front for me please?
It's metal bracket that goes underneath the top of the mouth of bar, it's screwed into the reinforcement bar. I need to make some so the number plate doesn't have to be zip tied on lip...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
