the auto barn fire extinguisher comes with a bracket. just drill out the hole a bit (get a workshop to do it. if they wanna charge you for 30 secs of work go somewhere else) and bolt it to the rear seat tab. then screw the other end into the floor pan with a self tapper. its not gonna go anywhere.
blue and red contact from news agent = win. All of $5ea for a roll of 5M, that is a lot of triangles.
fire ext easy to do with a bit a metal from bunnings, plus something to cut it with and something to drill holes with.
What's the red triangle for? Says nothing in the sup reg about that. Only says blue triangle and tow stickers
got the stickers... NOW. for the extinguisher. lol. grant, i come to donny you do for me? i bring you a blow up doll.
Don't have drill or drill bit strong enough to drill metal...
But tafe do have them.
trackday at nationals alvin?
Hey Cass, odd I know but can you measure number plate brackets on front for me please?
It's metal bracket that goes underneath the top of the mouth of bar, it's screwed into the reinforcement bar. I need to make some so the number plate doesn't have to be zip tied on lip...
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
