Have transitioned from a barbarian to a civilized computer programmer living inside the digital frontier.. on the grid
Personally I think Conan is much cooler. Who else can take out a camel in a single punch?
Thought u weren't taking your car on track ever again Grant? Grown a pair?????
I'm not taking it to track, I'm spectating.
May doing trackdays when I can afford to...
E-flex. Hamish reckons she might get close to 340kw.
Just keep winding in boost til you get there? lol
This statement is legit as I shall be in attendance at the obsurdly early hour you have requested.
Car is nice and low now should be a great drive up .... How long it take?
I didn't make the call, blame Ash!
and yeah should take a while, as we'll all be on our best behaviour :rolleyes:
TAFE carpark, I've spotted VE Maloo on red P's and couple of spots ahead, VY Maloo on green P's..
Would hate to be there come insurance renewal, must be at least $6k per year for them.
I raise you on this.
I saw a 300C SRT8 or whatever they are being driven by a RED P plater yesterday on the way home. I hated the flamin mongrel
Yeh it's early as Fk mad afternoon nap while woman drives back :laugh:
You got two up on me. Woman doesn't know how to drive manual and also don't think shes coming.
Never been there before, but heard there are quite a few speed camera hotspots on the way?
Heaps of p platers in nice cars... Remember pic of sls amg with p plate?
some kid here has on of those audi 4wd's dont know what theyre called but well up there in price..
he works in collections. dont know how people afford something like that on collections..
Just worked his ass off in the collections department yo!
You can do it too
Jokes.
I don't even have a girlfriend lol
Relatively cars are cheap if u finance it live at home etc what's 1-1.5k a month if u work full time live at home ? I mean that would easily get you a 60-85k car
Good point there sir, but I guess this would only apply for new cars.
2nd hand cars would be a different story though, interest rate on a personal loan would be a killer.
This isn't direct at you Alex. I know your on a high salary so you get my respect brah.
VE Maloo > 300C thingy.
Unless the Chrysler owner paid for it by him/herself.
You all lose out to this:
That picture was epic and made me hate life more than most things do.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
