Not a bad weekend, winton was the highlight for me. Ended up leaving about mid way through show and shine only so much you can look at really
Would of liked a messier sat night shoulda stayed in town longer ah well
Anyone watch the f1? Vettel just walking all over the rest..
Everyone seemed to have it this weekend. Top job on the steak alvin!
Dezz wasn't me in maccas but I have wicked sunburn...was a bit breezy at winton and didn't even realise I was burning until it was already wayyy to late
right. build is on. bought an HKS GT-SS for the s14, and lined up a manual gearbox on NS. going by vicroads tomollow for club reg paperwork.
need to contact chasers to see when they're free in the next couple of months to drop the car off.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
