Not a bad weekend, winton was the highlight for me. Ended up leaving about mid way through show and shine only so much you can look at really
Would of liked a messier sat night shoulda stayed in town longer ah well
Anyone watch the f1? Vettel just walking all over the rest..
Everyone seemed to have it this weekend. Top job on the steak alvin!
Dezz wasn't me in maccas but I have wicked sunburn...was a bit breezy at winton and didn't even realise I was burning until it was already wayyy to late
right. build is on. bought an HKS GT-SS for the s14, and lined up a manual gearbox on NS. going by vicroads tomollow for club reg paperwork.
need to contact chasers to see when they're free in the next couple of months to drop the car off.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
