Shit sounds creepy Kaz. Get some sensor lights. And maybe leave a few lights on in the house when you go to sleep.
I'd be more worried about your safety rather than the contents in your house.
Also find something to use to defend yourself with or even see if any friends can sleep over for a bit.
maybe u and dezz can lend me your 'guns' for a few weeks.. they're detachable right?
Top Gun show has a few bookings over he coming weeks. But can squeeze in an SAU member.
Payment can be made via Pizza's
Lookin at Tony's Nats photos....Who the f**k is Justin Gould and why does he feel the need to comment on EVERY SINGLE f**kING PHOTO
Also think I spotted myself in one of em, but can't be sure lol
some of the comments made me lol though
Just a mate who was supposed to come up with me but was in Sydney. So for the lulz he said he has going to comment on every single photo. Ran out of ideas and began to realize other people were viewing the album so he just stuck to the word 'Nice' lol
He is a huge kent and drives an R32GTR.
Didn't see you at SnS Dezz going ninja on us wastelanders.
I would think that my coil packs are on the way out, car stuttered a little when we drove into shep.
Also, front inner side guard liner (that never fouled) is destroyed lol. Looks like Swiss cheese
I saw that Kakimoto 33 as I was leaving Shep, shit looked so good. not that I saw much of it.
The red one? Thing had 13 inch wheels and 335 tyres on the rear, f**king ridiculous.
Going the drifteks?
I have 3 weeks of forced annual leave at the end of the year. But can go whenever.
Need to find price first. Not really keen on spending spending any more than 1k for rims. Might even end up with cheap rota's lol. Though them drifteks do look the goods on that white 33
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
