18x10+38 wouldn't that be sucken without a spacer?
nah, this is 18x10 +38 on the rear with no spacers
edit: says no spacers on this website
http://speedhunters.com/archive/2010/06/23/car-spotlight-krishs-lowdown-skyline-r32.aspx
Just now realised the Power Rangers weren't all that tough...they just ganged up on their enemies like a pack of lebs on he streets of Melbourne...I see you too Planeteers.
#teachingchildrengangmentality
does anyone else find it impossible to go through twisty roads as passenger and not get badly sick? sunday night was throwing up from 10pm-5am to the point were just blood was coming out...
head's been spinning for the last 3 days
i should've just come to this nats thing
can someone link me to nats gallery other than what's on fb?
There's some on Nats section of this forum.
Having trouble selling it?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
