Subaru owns the Toyota IMO...I bet they will turbocharge it before Toyota do too.
Will be the first good looking Subaru, I guess it helps that they have functional fridge manuacturer Toyota on the other end of the design spectrum lol. These look like baby 370Zs.
why a falcon diff?
On fb, Moh posted a screenshot of a dude asking if R33 diff will fit in his BA Falcon.
This bloke asked this forum, on transmission section I think.
