Special mention to Grant from the Wastelands for coming out last night. Can now understand where your coming from when mentioning social interaction. And also nice to meet you and hopefully will again in the future :thumbsup:
+1
cruise ended too early :P
I was up for mt.dande afterwards!
I was behind GTRRKT on the way up. And that was fast enought for me.
But I drive like a grandma :D
Oil temp went up to 125-130c on the run up though. Was getting a little worried...
Your oil weight is too thin.
Go for 10/50 or 10/60 at next oil change and better do it ASAP cos real summer's coming shortly.
Mine is approx 85-95 degrees (factory gauges are useless compared to Nismo units *sighs* more thing I miss...).
Which number is the weight the lower or the higher one? I can't remember?
I run 5w 40 Motul 8100 fully synthetic.
What sort of oil temps should I be worried with the rb25? And what are the consequences on the engine if the oil temp is high?
Just did an oil change :(
Weight is higher.
5 is good for quick warming up. That is what Nissan recommend. 40 is bit too thin for summer climate, I'd go 50 or 60 though.
I went home via the Esplanade again, get held up by Subaru Outback for 4 minutes, aargh! Luckily he/she pulled over to some spot.
Lol I was just cruising up...I had that stock blue S15 in front of me.
My oil temp was only on 86c on the way up.
Cruise up was fast enough for my gf :D
time for an oil cooler? :P
Though about it but it's my daily :/ oil will never warm up driving to the train station lol
Yep, I was hidden in amongst the three white boys I had in my car.
Last night was good fun. Great organising Tony and great turnout.
The only problem is now I want a R34 GTR so I can go fasssssttttteerrrrr...
The uphill was awesome and the drive home was heaps of fun. Great to see the Ae86 starting sideways at the lights...
The only problem is now I want a R33 GTR so I can go fasssssttttteerrrrr...
Fixed for accuracy.
the 50/60 is the protection of the engine or highest operating temp
and i think the 0-15w is the cold operating temp or something like that
I forget, its been a while lol.. but my uncle is a lube specialist at Mobil and has previously said anyone from SAU can call him anytime to ask questions if you like :)
the 'weight' of the oil is for the lower operating temperature, as the other number represents the part of the oil with the higher kinematic viscosity at the same temp
edit: im a dipshit, must read all posts before replying >_>
Edited by WGNPWR
I think you mean old school Toyota Supra :)
Also I must say that red M3 was fast :ninja:
Indeed. Was chasing him, he can drive that is for sure.
If Michael (miguelone) doesn't slow both of us up, Chris would kill me both in Esplanade and Arthurs Seat.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
