Rimspec what's the best way to get buff for summer lol
Summer is just around the corner. Shoulda started a lil while ago lol
Btw if any of you homos want some hand cream.. I got a tray load from work today that thy were giving away. You can probably fap with it if you prefer.
No homo
I'll take a tray load. no homo.
Poor wanzi. I was going to tell him to type it on the calculator... But meh. :P
BTW, Moh should NOT do this, correct?
BUUUUUUUUT. On the right, it looks pretty good. Iunno. Its an acquired taste.. :P
Edited by PENGUYEN
How's it goin Dezz? Enjoyin it ?
Leigh get on the roids and smash gym probably left your run a bit late for this summer
Yeah good so far, much better than my old job...Actually doing shit so not watching the clock etc, and way more laid back than the cock suckers at the old job...
Phone was ringing this afternoon around 2:55, didn't know the number so I just let it ring out. Then one of the other guys in the crew comes and tells me they want me up at the office...Get up there, missed call was from one of the foremen...Told him I didn't answer coz at my old job you'd get fired and he just laughed lol
All day?
Pretty much...shit load of switchboards going in there, we only put up maybe 5-6 today but did a lot of prep for more tomorrow
Sir why are you stuttering?
Yes, yes :)
No.
Yes, correct.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
