havnt spoken to her yet. but judging by her FB I think shes "seeing" someone..
Doesn't mean you can't put in a word for me.
Can you at least send/MMS me a pic of her again, I totally forgot what she looks like.
ill speak to her tonight.. i have to find out whats happening with the cash anyway. i didnt end up getting it. ill message you after
DRIVE [sOUNDTRACK]
Performer : Various Artists
Label : Lakeshore Records
Release Date : October 11, 2011
Composer : Cliff Martinez
TRACK LISTING
1 Night Call
- Kavinsky & Lovefoxxx
2 Under Your Spell
- Desire
3 A Real Hero
- College feat. Electric Youth
4 Oh My Love
- Riz Ortolani feat. Katyna Ranieri
5 Tick of the Clock
- Chromatics
6 Rubber Head
- Cliff Martinez
7 I Drive
- Cliff Martinez
8 He Had a Good Time
- Cliff Martinez
9 They Broke His Pelvis
- Cliff Martinez
10 Kick Your Teeth
- Cliff Martinez
11 Where's the Deluxe Version?
- Cliff Martinez
12 See You in Four
- Cliff Martinez
13 After the Chase
- Cliff Martinez
14 Hammer
- Cliff Martinez
15 Wrong Floor
- Cliff Martinez
16 Skull Crushing
- Cliff Martinez
17 My Name on a Car
- Cliff Martinez
18 On the Beach
- Cliff Martinez
19 Bride of Deluxe
- Cliff Martinez
:yes:
Saw the movie Horrible Bosses last night
Be careful the dentist doesn't put you under then takes nude pics of you.
Just sayin.
LOL, dentist is done and dusted, I've got infected wisdom tooth.
Would need to remove left side first then right side. $550 each side, earliest I can have them removed is 14th December - Am going to ask them if the earlier is possible in few weeks time.
On the bright side, it isn't as steep as I'd feared and gives me enough time to save up along with few stuff I want to do...
kadir needs to stop whatever shit is going on with dezz and alex, and its not like alex and dezz are provoking him either.
at least fords look nice from some angles, this is just boring giving each other shit, and its not funny. because it isn't mohsen.
Is that what I did, Michael? I humiliated you? Oh my God, I'm sorry.
humiliate me? You'd never be in a position to humiliate me, but it's good to have a dream.
lol saw that episode not sure why they bother having doors get smashed every episode
probably why they are made from cardboard. lol
Was gonna say, looks like balsa wood....
Like Alex said, he's not even worth the tiny amount of effort it takes to reply to his woeful attempts at insults
Good to hear
Did any more info come out re vettles tyre comin off last night? Was a rather boring race all in all webber could have done better but a 9 sec pit stop will do that to you
Where's next race?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
