They're quite an expensive unit.. currently still nearly priced $1.5k for the pair
Yeh but your car doesnt even work and they'd look heaps better on my car
Im prepared to offer a box of cheezles and a burnt copy of the drive soundtrack
Also only pays well if you look the part...don't care how discriminatory it sounds, if you're fat or a runt and you're trying to tell someone what they should or shouldn't do in their exercise routine, it never sits well with the psychological aspect of personal training.
Someone should tell the clients paying one of the several fat PT's at my gym
I would want to top myself if I worked in a bank or call centre. Actually I did work in a call centre once. I lasted 2 days then cracked the shits and quit haha.
I'm not quite a beggar yet. I'm a chooser :) And I'd rather do something I enjoy.
well if your saying that what your currently doing isnt paying the bills, then obviously someone else is.. hence begging.
i work in a bank. but not on the phones.. but you have to start somewhere.. especially as you said you want a career and not flip burgers at HJ's
You know how you said it was impossible to cram a semesters worth of physics in two days birds? Well i did it. and i feel good about the exam. finished it all. at least a B+ xD
I said it was PHYSICALLY impossible, not mentally! And it was just a bad pun too. Well done fuckface.
Only good looking one? Are you saying you wouldn't be with Kim herself? If so, faaaaaaalaming homosexual.
Perhaps this one is more to your liking...
Lulz @ the second pic - Would engage/challenge a boxing match if she had arms like those
Kim's got a fat ass and i personally like them when they're petite and well shaped, besides shes too dark :P
Go date edward off twilight then you white petite loving phaggot
Would bury my face in Kim K's boobies
She has some sweet bootay
its all about the curves bro!
ass n titties ass n titties ass n titties ass n titties ass n titties
Looks like a fellow member of darker complexion might have been offended of my love for whiter girls :whistling:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
