f**kn kadz. i swear you are the biggest dick head and should be euthanised
We just need to accept that some races as a whole are just better than others. As an individual you might be cultured, educated than the average Joe but can you say the same for the rest of their fellow countryman? Doubt it.
However, Germans as a whole are just supreme beings :)
For instance, Arabs can ONLY become something when goat lovers lead them or take over, as has been the case since 900 a.d.
No offence Mohsen. As an individual you're a top fella and 100% better overall than the rest of your fellow countryman.
Edited by Flynnn
33/34 Hicas is electronic... No crappy lines to worry about like 32's ;)
There is actually a DIY on here, it's not hard to do at all.
Knew I should have bought a 33 four door instead. Stinkin 32 haha
Billy come do mine for me if it's so easy haha
As much as I would like to
Disagree, you are partly right. I won't bother explaining.
But I do look forward to the upcoming Israel and its little bitch v Iran and Syria war ;)
the sphincter of the universe is no position to ally with Israel when it has been condemning the state for the past few years, not to mention the flotilla incident last year.
This isn't Iran's business either so i very much doubt Iran would get involved considering its busy fighting off (politically) or preparing for a possible attack by US.
There might be a high possibility that the sphincter of the universe just might move in, militarily, to free the people from the brutal Asad regime/dictatorship.
The land of goat sphincter rings military is already preparing as quoted by CNN
http://www.youtube.com/watch?v=i-6aGfW76ck
Brutal? Not at all mang. Keep believing the western propaganda.
It isn't the government v the people. It's Islamists v the government.
Family in Syria has confirmed this.
Btw, if you want to discuss this, pm me, let's keep it off the wasteland.
will be next year some time. i will definitely!
I asked Luke Youlden to take my car for a couple of hotlaps to show me the potential. (he was one of the instructors on the day) Opens up your eyes to what your car can do with a pro driver who has nothing to lose haha
Long story short, brake fade and melted my dust boots in the calipers :( haha
f**k lol
i'd just like to put it on the track, maybe i could learn more about this car!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
