You know what mayne i only make $40k a year and very content. Good luck with the sparkie job and landing a EBA or what ever :)
I had to take my US trip on a credit card and looks like i might have to do the same again when i go in the next couple months :)
I'm already on the EBA.
hmm
On the 10th of May 2011, the 2011/12 Federal Budget was released with a focus on Fringe Benefits Tax as it relates to motor vehicles. These changes simplify the treatment of FBT for the future. The new regime also makes salary packaging a motor vehicle more beneficial for drivers travelling low annual kilometres.
must know what they changed
done quote sent off to lease plan
lets see what comes back
surely cant be that much difference
if i can get a brand new dualis or cruze on 160 a fortnight
the dualis is 26k so an evo 8 around 32k cant be that much difference
im surprised how much my 33 cost a month to run and im not even paying it off
insurance - $111 a month, $55 a fortnight
fuel - $30 a week, $60 a fortnight average
rego - $650 a year, $25 a fortnight
ah its actually 140 a fornight, still a lot given $0 finance
hmm
All you need to do is ask.
Government is introducing a statutory rate of 0.2 to be phased in over the next 3-4 years to calculate the FBT liability instead of different rates for different KM's travelled IIRC.
what's with all the kids these days getting inked up :/ how bout learn to use a pen first before getting a pointless tatt that "looks cool/chicks dig it bro"...
little kunts shit me
lol whata cool kent
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
