Maybe get your cousin to buy the car, own it for a year then send it back.... Would be the best way to do it.
Hrmm now you got me thinking. Will check out the UK version of carsales for fun at lunch time.
Import a R35 for track purposes... now that's worth something to think about.
From the US? There's something better there such as Corvette Zr1, Camaro zl1, Mustang etc but they're compliable, only personal import if you can't comply here in Australia, otherwise its waste if time
UK ain't all it's cracked up to be. Their petrol is ridiculously expensive and enjoy your rego on anything with more than a 2 litre engine...then there's the ugly, fat and depressing lifestyle/weather.
Import from the states = $30k to do a proper conversion from LHD.
It's not as easy as it sounds; for every loophole you can think of around paying high prices for cars locally, it's all been thought of / done before. This is reflected in the prices of our local second hand market and the overseas import markets. It's the reason why you can go to Japan and buy a 1998 RX7 for $9k, whilst a 1999 RX7 will cost you $18k - the latter can be imported to Oz.
Buy a delivery km Mustang in Australia for ~70k-80k, the same car will cost you 35-40k in the US...add your RHD conversion, shipping etc. You might come out 5k better off after the hassle and risk involved in importing yourself.
Personal import is probably the only thing worth considering to save money, if you can pull it off...
I lol every time i see a Mustang or a Camaro... Apart from the fact that they aren't very good cars
Die in a fire!
Actually... Now i have me thinking, My sister is there on a two year Visa... She won't drive so would just need to store it for a year :3 hrmmmmmm
Then there's the ugly, fat and depressing lifestyle/weather.
Die in a fire!
Hey! I meant the new ones of course! I love the old muscles, and you don't need to convert them so of course it's worth while. Just not worth importing a car for $110k when it's ghey, they're just an American Commodore. C-o-m-m-o-n. As for the old schoolies they are super cheap in the US as well and I would definitely approve importing one.
Also the UK might not be that fun to drive in, tolls into the city are disastrous as well. It's more about popping over to France, down through Andorra to Spain or Switzerland to Italia. Mmmmmm Alps. Nom nom nom.
Edited by Cha_Chaos
So a quick look on Piston heads shows:
08 M3 ~ 30K
04 Gallardo ~65K
07 911 Turbo ~ 50K
Today exchange rate = 0.63
So for say the 2007 911 Turbo ~$80,000.
I have no idea on the costs and hassles of importing from the UK but just putting it out there....
Strong Aware.
Impressed.
Baffled.
You have to use the car while you're there
It would be registered but not driven... My sister doesn't drive and who wants to when you have the tube. Would be treated like a standard car except it wouldn't increas in km's.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
