Also the UK might not be that fun to drive in, tolls into the city are disastrous as well. It's more about popping over to France, down through Andorra to Spain or Switzerland to Italia. Mmmmmm Alps. Nom nom nom.
Not all of us can take a month out of life to drive the autobarnzzzz :glare:
Skyrim is such a fkn awesome game. Can't wait till I get home and play lol.
I jumped these bitch ass elves, arrowed one mofo in the head and ran a great sword through the other. Then I stole their horse.
Full broady spec.
Gonna lol so hard when you come on here whinging about how you got stomped by a giant. In fact, I want you to quote this very post when it happens.
I did encounter the giant...
I kinda turned around and GTFO'd ASAP lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
