Wah wah.. and f**k its not my problem the bish has a boyfriend?
if you want I can tell her again, but you dont want to come off needy do you now.
I wanna go garage cafe never been where all our invites
You said she didn't have a boyfriend...or that it was shaky...you promised me shaky. Nah don't tell her again, that does sound desperate, I just thought you were hanging out with her soon and you were gonna ask her on my behalf for a date :)
Get a gixxer
Fffffffff sore spot ;)
Get a gixxer
I already have one!
Good day sir.
Thats awesome. Never seen a girl on a track with a bike before.. srs.
I want a bike now :)
Doo iit. I have a fluro yellow helmet on the way and am stickering the fairings in fluro red and yellow in a Tron Light Cycle inspired design of course! Can't wait to finish it and have my own Light Cycle :wub:
we are soon i guess. i havnt needed money lately so i havnt bothered chasing it..
nah new pics of her keep arising with some skinny indian flamin mongrel so im assuming shaky is now settling
whos going to garage cafe from the SE?
It's not about needing someone else to do the work for you ya dick, or them doing all the work for you (for that matter), ever heard of a wingman? If it was someone I knew and had met before then there wouldn't be a need for it, tis not the case.
You can be my wingman anytime Maverick
i duno the guy looks like a scrag. and you know what type of guys good girls look for nowadays.
Skinny fucks with a pink T-shirt, tight jeans and a bad haircut?
Couldn't believe that either when I read about that...pretty amazing how tall it is in first...100 would have sufficed!
My friend wrote his off 2 weeks after buying it brand new, hit a patch of gravel on the road and he was gone :(
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
