Wah wah.. and f**k its not my problem the bish has a boyfriend?
if you want I can tell her again, but you dont want to come off needy do you now.
I wanna go garage cafe never been where all our invites
You said she didn't have a boyfriend...or that it was shaky...you promised me shaky. Nah don't tell her again, that does sound desperate, I just thought you were hanging out with her soon and you were gonna ask her on my behalf for a date :)
Get a gixxer
Fffffffff sore spot ;)
Get a gixxer
I already have one!
Good day sir.
Thats awesome. Never seen a girl on a track with a bike before.. srs.
I want a bike now :)
Doo iit. I have a fluro yellow helmet on the way and am stickering the fairings in fluro red and yellow in a Tron Light Cycle inspired design of course! Can't wait to finish it and have my own Light Cycle :wub:
we are soon i guess. i havnt needed money lately so i havnt bothered chasing it..
nah new pics of her keep arising with some skinny indian flamin mongrel so im assuming shaky is now settling
whos going to garage cafe from the SE?
It's not about needing someone else to do the work for you ya dick, or them doing all the work for you (for that matter), ever heard of a wingman? If it was someone I knew and had met before then there wouldn't be a need for it, tis not the case.
You can be my wingman anytime Maverick
i duno the guy looks like a scrag. and you know what type of guys good girls look for nowadays.
Skinny fucks with a pink T-shirt, tight jeans and a bad haircut?
Couldn't believe that either when I read about that...pretty amazing how tall it is in first...100 would have sufficed!
My friend wrote his off 2 weeks after buying it brand new, hit a patch of gravel on the road and he was gone :(
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
