you need a 200k r8 for that? :huh:
probably not 200k for them
Is it black or dark blue? With bright-ish headlights?
what is this bright headlights you speak of? like they light things up so you can see? amazing!
Yeah dark blue.. wasn't a mate of yours was it? If so, sorry about the top bloke call lol
Ah yeah, seen him around, dubt he'd wanna be mates with a bloke who have purple datsun...
So...who repping at the Show 'n' Shine this Sunday? And who coming down for a looksy?
ME!
Providing I can find a parking space...
Yes amazing, by Lamborgini Countach standards....
...it has HID's, hence brighter light for '70/80s car.
A parking space? You aren't putting your car on display?
Yeah, I'm putting it on display whether it's dirty or not.
By parking space I mean, park in the 'parking space' for the SnS.
There's plenty of space, remember last time? We had to space out the cars to make it look bigger lol. Should be a bigger show this year with better expected weather.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
