Tough wheels!
I like'em.
Or just get Charles to vinyl wrap your spoiler :P
Don't think vinyl wrap in CF will look good on purple.
Sticker bomb would be though, just need to find some.
Still not sure about the Panasports though, just walked outside to get mail from the letterbox, watching the R thinking, man, 17s does look tiny!
I meant get Charles to vinyl wrap it in purple or try and match your colour as close as possible.
17" will look tiny on a R33 GTR, you need to go at least 18".
Jamie, if I'm going to wrap it, I'd rather to have it stand out. If I'm going to wrap it in purple, I may as well paint the whole spoiler.
Yeah, for me to go 18s I'd have to grab a softer set coilovers than what I've got in mine atm, and grab swaybars - more money down in the drain...
i have some sticker bomb at mine if you wanna try..someone needs to take it off me before i keep going.. lol
600x600..
What happened to eastside imports club or whatever it was called..?
Ask Jezza Boi as he started that.
I think they are still around, but Vic Imports Clubs was the branch off club from SEI, which is growing quiet big.
True, sticker it up yo!
Haha!
you'll get there.
I'm in 2 minds about it, the coilovers I've got in makes the R handles really amazing (don't have any other form of handling bits) but it is way too harsh for street driving, one uneven surface, my driving position changed that instant - which isn't good should I want to make the R faster...
Atm, looking for softer coilovers, so far seen Tein Driving Master - need to do research whether how stiff it is.
600x600..
Hey, not sure if this much will cover the area I want, where did you buy them from?
Harsh ride? Time to man up
I don't mind it actually, but I'm not sure if I wanna wreck wheels this rare though.
Yes, I'm a girl now, deal with it.
I don't disagree with what Alex is saying about lock in times, it's a legitimate reason for some people not entering. I don't mind staying the whole day, I can always leave my car there and go do something else...doesn't suit everyone though.
I just want to say one last "tl;dr" passage, that committee do take suggestions on board...it's stupid not to listen to your own members. But most of the time, the issue being raised is one that's already been discussed by us (~10 people). A decision has to be made, and sometimes we end up divided over it. Anyone can spot problems, coming up with an actual solution to keep everyone happy is another thing. If you've got a solution, send it through...I'm not being a smart ass...trust me, they will 100% welcome it if they can't fault it. That's all committee is, a bunch of fellow members critiquing items and throwing ideas/input at it until a majority agree on something...because 10 minds are better than 1.
Docklands only want us to move cars in and out during non peak times, being the start of the day and the end of the day. Which is a shame, because it is an awesome and central location. So then you change it to something like Caribbean Gardens, where you can drive in and out...suddenly you're snubbing the west siders who cbf driving an hour to the SnS, and I can't blame them for that.
Anyone want to help with / do a boot install for $$$?
No waiz.. what did you have back then?
Knew some people from Mccr, it's a shame they no longer exist. The club exec. was a dude with a black Mr2 and i believe he also had a powerful soarer
lol I was on my L plates when MCCR was around...only went to a couple of cruises, hung around the forums a bit.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
