i r intending to go to the city :P
usually i just go to the city for specific events, much easier to get a cab home/call the gf when i go out local, but ceebs that tonight
tell me clubs kgo
Depends on what 'sort' of crowd you want to hang around with and music.
Been retired from the scene for a while but Alumbra, CQ etc seems to be pretty popular
And like rimona said, they'll no doubt be thinking about how their car was keyed as a result of their carelessness, so in future they'd no doubt be more careful. Who knows jeppe, they might park next to you one day, maybe you should thank rimness.
If the person knew they had done it and intentionally ignored it then you have a point. But we don't know if that's correct. Maybe they had their earbuds in playing loud music and their dad had just died so they weren't thinking. You just can't make assumptions.
And there's a word for how u just forgive everyone that wrongs you, it's 'pushover'
Hahaha, actually dude people don't wrong me. That's why I can forgive fools that put me in hospital and take away major parts of my life by almost killing me. I have an incredible family, friends, life, and my mother always taught me forgiveness first and foremost. If that's the definition of a push over then I'm quite happy to be one :)
wana go somewhere where i can get in wearing hightop nikes and have a good time :P
Took on 4 and lost I presume? Dirty way to fight not restricted to lens really..
You try pretty hard to pass on the persona that your high brow/ high society, I don't think its working man.
Their level of comprehension is almost non-existent, therefore they're often reduced to a animal-like behaviour. The only way to teach a dog that don't listen is to beat it, what else can you do with a mongrel who's prerogative is bigotry :domokun:
What kind of music?
Unless you hit up the emo clubs you'll struggle to hit a club with high top Nikes...would have to stick to bars or pubs.
That's one way to go about it, or you could wake up and live in the real world.
Wah wah will let you in with high top nikes, shorts and singlet etc. Anything else and you're over dressed.
I'm sure you beat them
Black or white dress shoes, plain shoes, the kind you wear with slacks or a suit.
Check out Retro or Loft, or as Dezz said Wah Wah if you want to go underdressed.
why do people want to go out dressed like a punk i dont get it, dress nice get a hair cut and be sharp unless your a celebrity punk/emo/metal rocker its not acceptable.. deal with it
Cos it's comfortable?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
