Moshen was that you on the TV this morning explaining how the load shifted on your truck and you managed to bring down the bridge pile on??!!?
Anyway, events for next year.
Needs peoples onions, crap or even crapper?
http://www.skylinesa...scavenger-hunt/
http://www.skylinesa...5601-mt-buller/
http://www.skylinesa...85602-gor-2012/
Loool. Feel like posting a troll sale add now.
FOR SALE
R34 GTV
MODS
STANCE
114,000 k OBO
Thought I had a spun bearing... :P
Didn't think I had to mention "decent car" as one of the criteria Mohsen
Seriously, my 4 door.
Coilovers, Advans, 34 seats, plenty of spares...
Edited by Miguelone
Or he's successful in bribing the road authorities?
I agree, thats's incredibly dodgy! 'Sif the rest of us should get punished with no mercy while he gets to do what he wants. Maybe in Europe but you can bribe those cops with almost anything, and at least it's consistant. Special consideration? Grumble grumble grumble >_<
You think I'm paranoid? Wait till you meet my friend. Lulz
homygohd bro, i turned the car on and it made this noise, thought the engine was broken, then I realised it was my sick subwoofa.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
