Moshen was that you on the TV this morning explaining how the load shifted on your truck and you managed to bring down the bridge pile on??!!?
Anyway, events for next year.
Needs peoples onions, crap or even crapper?
http://www.skylinesa...scavenger-hunt/
http://www.skylinesa...5601-mt-buller/
http://www.skylinesa...85602-gor-2012/
Loool. Feel like posting a troll sale add now.
FOR SALE
R34 GTV
MODS
STANCE
114,000 k OBO
Thought I had a spun bearing... :P
Didn't think I had to mention "decent car" as one of the criteria Mohsen
Seriously, my 4 door.
Coilovers, Advans, 34 seats, plenty of spares...
Edited by Miguelone
Or he's successful in bribing the road authorities?
I agree, thats's incredibly dodgy! 'Sif the rest of us should get punished with no mercy while he gets to do what he wants. Maybe in Europe but you can bribe those cops with almost anything, and at least it's consistant. Special consideration? Grumble grumble grumble >_<
You think I'm paranoid? Wait till you meet my friend. Lulz
homygohd bro, i turned the car on and it made this noise, thought the engine was broken, then I realised it was my sick subwoofa.
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
