The downfalls of livin, and getting used to livin like a baller'
Regular $500 lunch/dinner payments and $5,000 withdrawals every time you go to Chadstone.
And probably a whole lot of other stuff I don't see.....
800k WTF! How can u go broke that's like 3.2million in the last 4 years! What's he do for coin if u can say tony?
Not sure Leigh depends if the boss has made plans maybe caraway meet? Easier for me to get to lol
Also Charlie, I ride motorbikes.. probably once a week lol :P
Let me know when to rock up with it to a SAU meet
oooOOOOoooo, want to come to a track day at Phillip Island on the 16th of January? I'm getting a group together which means we get a discount and it's an awesome day :)
Rhymes with Stock poker :P
Edited by blah_blah
oh i see. dont really know why these dream boats make so much money when they don't produce any real goods, and pretty much do nothing for the economy anyway.
anyone know anything about animal genetics? a molecular biologist will be great!
and i still need to borrow an impact socket.
Fucking investment bankers and brokers lol, doesn't make sense that people who save lives earn so much less than these people!
Agreed. They had some crazy stat recently on how many people would die because nurses went on strike. Ridiculous, lives are priceless. They should be paid much more.
As tony would know they get paid based on the profits they generate you can't comapre private industry to public
For him to earn 800k he must have generated millions and millions of profit probably tens/hundreds of millions
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
