It cost me $400 to respray front bar in Midnight Purple, dark blue is common colour.
Birdmang, $350 and tell them to STFU or demand 'happy endings' for both girl and mother included in the $640.
How much cheaper?
Break it to him by slapping sense into him and buy a Skyline - gearboxes doesn't break into pieces on stock power in Skylines.
Only about 1k cheaper than your average 04 WRX sedan. He doesn't like Skylines because he thinks only try hards drive them or something, his last car was an 03 mazda astina he wrote off
So, get a phone call today from mother of the girl I had a lovetap with in peak hour traffic the other day. 2001 E36 318i, I scratched her rear bar a little (it already had a few scratches) and she said on the day that she probably wouldn't bother chasing it up...I offered to pay for touch up paint etc. Went on our merry ways. Now I have this phone call from the mother saying she took the car to a panelbeater and got a quote of $640 to respray the rear bar...am waiting on confirmation from panelbeater mate, but does this shit sound excessive to you guys? I would have thought $300 tops for a rear bar, it's a bloody 10 year old pov spec beamer :/
They probably told the father/bf etc about it and thought hmm maybe we can get the whole bar touched up etc at your expense..
Also, a confirmation from the panel beater means f**k all really he/she's probably
her mate/relative etc
Edit: aparently the panel beater is your mate not hers..
Never mind
Edited by R-SPEC
Never mind
Yeah definitely trying to get a fresh bar out of me or profit from it. The girl couldn't even find the damage on her bar and said she probably wouldn't bother chasing it up. Said her dad fixes up cars etc., so no doubt he's had his input about it and assumes I'm naive. Anyway if her mum calls me again I'm gonna tell her I don't want to hear from her, I'll only speak to her daughter because that's who I had the accident with. I'll tell daughter that I'll get it repaired, or you can take $350, or we can go to VCAT and waste our time for much the same outcome. Might call a couple panelbeaters on Monday.
Thanks guys.
I asked a panel guy / spray painter that i was with when I said $650 probably should of mentioned that
Cool thanks for that. I'll see if I can find any cheaper on Monday, if they are all around 600 then bad luck I guess, I'll be more content with paying it.
get her one of them mobile dent/scratch removers they do a mint job on the spot and wont charge anywhere near that (if it's a small area)
my brother did the corner section of his rear bar (scratches/paint scraped) from memory cost him $150-$200 and the colour matching was spot on
Edited by R-SPEC
Hey may any idea the name of the place that did it? Someone backed into my bumper in Coles carpark and left without leaving details (barstards!). No panel damage only cracked paint on rear bumper:(
Problem is proving it was damaged prior to the incident unfortunately
This, it's a shit part of the law but if you're the last person that hit someone then bad luck for you. No wonder people drive off from accidents all the time, I'ma put one of those constantly recording cameras in my car now. All I'd have to go off is the damage to my front bar which is just a single paint chip...but it already had scratches, chips and stress cracks beforehand which would probably work against me trying to prove that the impact want great enough to do the damage she's claiming. My number plate doesn't even have anything on it! Anyway I ain't gonna think about it anymore or I'll have spent $640 of my time just thinking about the shit. They only got one quote, so will just talk to other panelbeaters on Monday and see what they give me to go on.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
