Didn't see turbos in the mods list, seems odd to run standard turbos after spending that much on the engine..
Any idea where it was built?
he probably ran out of patience and time haha. I do remember him mentioning new turbo's but never got a boost controller
Was rebuilt by ReCustoms
Ah yeah now I remember. It was sitting at RE for a very long time. It was there when mine went in for the build and still in the back corner when I left with mine
haha he made sure it was built right and didnt rush them. So it sat around most of the time and still does after the rebuild.
I want a r32 gtr now... haha
Surely you guys remember 386s before Celerons...I'm not the oldest here! 25mhz and 33mhz on turbo mode, 8mb (upgraded to!), 420mb hard drive...CD ROM with Sound Blaster!
I loved the turbo button. My first real computer of my own though was a Celeron 133mhz. Then I built computers for a number of years and moderated a huge AMD forum.
True story lol
Sounds alright, might have to head to the sticks for a test drive
That blue GTR is a lot of car for 27k.. much prefer to buy that than a stock 32 GTR. Duno how my mate managed to sell his stocker for 20k.. dash bubble and all :P
If i were buying again I'd deff get a modded one straight up
True story lol
Lol the turbo button... with it on the pc runs at normal speed, and off makes it run at half speed
Ron's GTR had pair of GT-SS in 2.8, now, it has pair of -5s, Nismo AFM and large-ish injectors and a re-tune by Sabbadin from memory.
I know cos he sold the GT-SS to me last year when I'd killed my standard turbos.
And $24k, f**king hell!
Depends on budget Dezz.
I know a very very clean 32 that's in the 30k region.
In the same league as this car. Both the above, and below, are Racepace built with perfecto bodywork
www.skylinesaustralia.com/forums/topic/386095-r32-gtr-silver-immaculate/
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
