I've been to Naples in the south, and it's one of the dodgiest places ever. Get off at the train station in Naples and you really have to watch your shit, lest it be snatched from you. I was ok, but unfortunately, the asian tourists are often seen as 'easy targets' and are set upon by the local scumbags. Once you keep going south however, into Sorrento, Positano and Amalfi, it's probably more beautiful than the places in the north of italy imo, so I don't understand why the northerners think they're so much better.
His quoting google wouldn't read into it too much, how was ya trip overall apart from been cut short?
Yeah it was awesome, really enjoyed it. Glad to be home though, Australia is without a doubt the best country on earth!
I have one of those getting resprayed at the moment...will be selling once it's done :)
Gotta really put your foot on the brakes to make them stop hahaha, even just keeping it still in D when you have the choke on :/
Belongs to the workshop, I'll post photos for you when she comes back from the touch ups. Fun thing to cruise around in but we only bought it to do up and sell. Pretty immac condition!
No idea yet but probably more than the one you posted, which looks like a pretty good deal if it runs as well as it looks. Let you know once we get it back and total
the bills etc.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
