I love this video. I was talking to my mate about this exact car today. You'll have to import/convert to get the factory supercharged one though
think only the 03/04 where supercharged and are too expensive. i'm looking at the 98-02 ones seem to be in the right price range
Such is the same dilemma faced by twits who buy neopolitan ice cream just for the strawberry or chocolate. Find someone who needs day tablets and work out a system of trading tablets with each other.
Front up to the doors yes, assuming you're talking about the 2-door since 4-door VZR's aren't eligible for import. Some interior parts are also interchangeable, some parts are different.
so front guards and bonnet are identical on all models?
wish it was that easy.. maybe my first world problem
Yeah love that video.
My mates LS1 sounds very similar. One day, that is what I'm going to do.
Blown LS3 or something blown euro
you should be able to buy a box of "night" cold and flu tablets... whenever you want night ones they are all gone and only day is left.. its a pain in a ass
Lol take it in the correct dosage and u'll be right.
I got plenty of night ones. Use the day ones too quick. I'll trade.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
