162 KW these days isn't much though especially with a slush box auto (but for back then pretty dam good)
SV6 / XR6s are P platers choice these days.. even though they're a boat they got a bit more power for teh burnouts u leh
I wouldn't mind finding a clean 32 GTR at some stage in the future for a track car but so hard to find one these days :(
Also:
if i saw a big shirtless barefoot tattooed kunt running at night i'd be thinking cops must be chasing him...
I run at night and even in running gear people slow down in their cars to sus out why someone is running along the footpath at sprinting speeds...then there's the shout outs from P platers in Commodores -_-
Grant bringing the heat
Dont sell panasports will look good as man
Well, have a set of Work Meister S1 3p that will fill the guards coming in couple of months time.
Thats harsh brah
Not harsh enough by the looks of it.
Making me want to get a pulley upgrade and tune more now!
Supercharged whine is pretty win, mines not quite that loud yet :P
do it. s/c whine > turbo spool imo
add on top of that the rumble of a V8 = all kinds of win
lol cant blame em. that's also dangerous ya know, cars/bikes/people backing out of their driveways....
