Battery strut brace is a sick idea, especially if it's adjustable and therefore universal fit to a lot of cars.
Unfortunatly all the gtst versions of skylines look like ass.
I hope it's related to power department.
DBA4000 slotteds
QFM A1RM pads
Braided Brakelines
800cc Sards
Nistune
Tomei Cam Gears
Basically getting most of the supporting things done so when I eventually do the clutch. I can just get some new snails bolt on and bingo bango extra power.
Probably -9's I'll probably only head to the track a couple of times a year so I want something thats nice and responsive on the streets. Having 300awkw is the figure I have in mind. Then I'll turn my attention to a nice set of coilovers then the car will be pretty much how I want it.
Yeah, I've been doing my research should be all good. Gotta save for a nismo twin plate clutch next, they are pretty damn pricy but from what I have heard totally worth the money.
Sounds like you've got heaps of mods lined up.
Nismo Coppermix is well worth the money, having driven friends 26 powered GTS4 after hard driving at DECA, clutch felt like stock, very impressive.
Yeah lots of mods lined up and no money to get it all done. Just gonna have to nurse my bank accound back to health after this round of mods and start to stockpile parts all over again.
DBA4000 slotteds
QFM A1RM pads
Braided Brakelines
800cc Sards
Nistune
Tomei Cam Gears
I wouldnt go the A1RM's if your car is a daily.
They are very harsh when cold and will chew through your rotors in 20,000km. Although are very good, its not worth chewing the rotors.
I ruined my rotors from 20,000km daily driving. Contacted QFM and thats the explanation they told me.
Use the QFM HPX's for daily and the A1RM's for track.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
