grant gave me a pet spider today! *crys*
lol no! thank god!
it actually survived an attack near the rear wing fell to the ground and was last seen running underneath the car towards the front very fast!
Yeah, it's fast, wanted to crush it...
So what's next on the list of cars to buy Alex?
Think Alex is lusting for FPV GT, the supercharged V8 thing.
Yeh plans are for a v8 at this stage bit above my range at the moment will get rid of Lexus as well when the time comes
Birds I'll pm ya I gotta get a roady which sucks but I think I should get one relatively easily
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
