its a GTRS high flowed into an s15 compressor housing.. so its not up there at 250 flow wise, but its a hell of a lot more responsive than it usually is.. Cihan said there was definitely more power he could get out of it, but i didnt want to push it.. im happy with 230kw in a car that weighs half as much as the stag lol
So it's buchered spec in other words :)
Just like when people try put GT3071/GT3076 cores into RB25 milled housings...
The turbos are NEVER as good as using their correctly designed housing :(
Anyone know of any insurance co will insure you with a import parked outside the house other than Just Cars.
Don't tell me to put my car in the garage and go Shannons, it's more trouble than its worth for my situation.
yeh i agree with you 100%, but i didnt do it. car runs fine, and has a power figure im happy with so for now its good enough..
that is if there is a dyno day next year.
with the lack of cars going on the dyno makes it hard to ask workshops to open up for the day to us.
think there 22 in total and some of those were cars chasers called up to make up some numbers.
excellent turn out and good social day but not a huge amount on the dyno.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
