http://www.rhdjapan....e-kit-r32-15821
It has parker, i think its the ring around the main driving light.
Works out to be $310 AUS.
Then I assume +shipping... Hmm...
The CF intake / headlight replacement looks great!
Yeah had I left it in there I would have got my money back, probably even made some, but no one knew when we were gonna pull out of it so I cracked the shits / sold up and bought a Skyline haha.
Ah well it's only money can always make more!
fml, high pressure sprayed my car and paint flaked off the windscreen wipers which i painted not long ago ~_~
Might have to get them powdercoated or something...
Or learn to paint?
Just sprayed it with black spraycan paint, but its coming off. What i do wrong? :/
Use Etch Primer, not normal primer. I sprayed mine 3 years ago, used etch primer and black over the top. The only problem I can see with mine are some chips here and there probably from bugs or stones.
Funny thing rates, it's actually good they aren't dropping in terms of the economy yet the sharemarket dips on the news and people get disappointed they wont save $50~ a month... Forgetting the upshot they still have a job! And a relavtively healthy economy
What car you going to build up?
E39 528I
scored it off my uncle. schwartz black, with peanut butter interior. found a late model wreck with the black leather m sport interior.. so i guess ill pick that up instead of the R32 that pat posted >_<
Fk airbags I can see your whine thread when u get done an have to rip em out for roady
valid point good sir.
but damn bags would be nice and comfy as hell
Moh, by the time you're done spending money on it, you're gonna wish you offered that guy $20k for his 540...which you'd be infinitely better off with anyway. And you could actually own a cool car for once.
Unrelated, just took this for a road test...if the gearbox and clutch weren't completely f***ed it would have been a lovely drive. There's something about sitting in lounge chair seats, holding a shoelace thin steering wheel at 40...mph...in 4th gear with a V8 rumbling away. Must build one, one day.
E39 528I
I see, you gonna do a build thread in S/W?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
