Ok mum
dont listen to these pansy asses :P
:3some:
It is possible for one to ride a 600 and not kill themself if they aren't retard spec :D (lol just realized your forum name is r-spec after I typed that >_< )
Afterall only 75kw!
Adam, I'm heading to UK/Europe.
man how long you going for?!
go Germany in late September and ill meet up with you for Oktoberfest! :P
I went 2 years ago and I'm dieing to go back :D
the UK not so much.. =/
:3some:
Afterall only 75kw!
lol :domokun:
its reverse learning, why learn at the bottom when you can start up top? i mean surely you can just as easily kill yourself in a 250...no? obviously bigger ones have more power but i'm pretty certain if i drove a veyron now i wouldn't crash it unless i was doing something stupid...
dunno kinda seems pointless really
I'd imagine a slip of throttle on a 250 is a shit load less likely to kill you than a big bike...
End of the day get whatever you want, you don't need to justify it in here, I don't think anyone is going to lose any sleep over it
you be nice!
Yeah but when thing go bad on a 250 the effects are lessened for noobs, your first ride in wet weather etc.
wouldn't the bigger brakes/grippier tires be more helpful then :P nah i said i might go for 600 coz i'm only occasional gona ride it for short distances, and cbf selling/buying
Leigh what kinda bike you got?
Pending Visa application (should be approved), will be there for hopefully 2 years as working holidays assuming I haven't ran out of money before then.
Was advised to head over Germany for oktoberfest... So yeah...
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
