Ok mum
dont listen to these pansy asses :P
:3some:
It is possible for one to ride a 600 and not kill themself if they aren't retard spec :D (lol just realized your forum name is r-spec after I typed that >_< )
Afterall only 75kw!
Adam, I'm heading to UK/Europe.
man how long you going for?!
go Germany in late September and ill meet up with you for Oktoberfest! :P
I went 2 years ago and I'm dieing to go back :D
the UK not so much.. =/
:3some:
Afterall only 75kw!
lol :domokun:
its reverse learning, why learn at the bottom when you can start up top? i mean surely you can just as easily kill yourself in a 250...no? obviously bigger ones have more power but i'm pretty certain if i drove a veyron now i wouldn't crash it unless i was doing something stupid...
dunno kinda seems pointless really
I'd imagine a slip of throttle on a 250 is a shit load less likely to kill you than a big bike...
End of the day get whatever you want, you don't need to justify it in here, I don't think anyone is going to lose any sleep over it
you be nice!
Yeah but when thing go bad on a 250 the effects are lessened for noobs, your first ride in wet weather etc.
wouldn't the bigger brakes/grippier tires be more helpful then :P nah i said i might go for 600 coz i'm only occasional gona ride it for short distances, and cbf selling/buying
Leigh what kinda bike you got?
Pending Visa application (should be approved), will be there for hopefully 2 years as working holidays assuming I haven't ran out of money before then.
Was advised to head over Germany for oktoberfest... So yeah...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
