pros and cons of club rego. kgo
It's cheap. That's good.
You need to be a member of a recognized club. That's bad.
You can only drive your car 90 days per year. That's bad.
You have to have a club number plate and cant have any custom hektik combinationz. That's bad.
Yeah log books. If you get pulled over and you haven't filled out your log book detailing the trip that day, it's the same as driving unregistered and you get reamed by the 'long arm' of the law.
Not to mention weekends you won't drive it, so you can save up some weekdays with that. However...if you drive between 11pm and 1am...I'm guessing this counts as two days?!
The car has to be 25 years old. That's bad
used to be just club events and you had to have all the doco for that, became too hard.
it's now 90 days and you have to fill the book in prior to departing as above no book unrego.
car still has to be RWC.
car has to be more than 25 years old
thee is a very limited number of clubs that you can be a member of and you have to go though them to get it,
not like cams where if you are a member your are automatically eligible.
So if you have an old car you hardly drive then it all good.
but as a rule they make it a pain to discourage you, and you only save a couple hundred a year.
I looked at it for the stang but decided full rego was easier.
I thought club rego meant you can only go to events and stuff not just run down the shops
I used to think so too but then I've seen heaps of cars getting around with em on weekdays. I think it's permits from Vicroads that allow you to visit events only.
130 for a year.. that's about 500
Are club rego transferable to new owner if you're selling a car with one?
No
Oh another
Easier to get mods allowed. That's good.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
