pros and cons of club rego. kgo
It's cheap. That's good.
You need to be a member of a recognized club. That's bad.
You can only drive your car 90 days per year. That's bad.
You have to have a club number plate and cant have any custom hektik combinationz. That's bad.
Yeah log books. If you get pulled over and you haven't filled out your log book detailing the trip that day, it's the same as driving unregistered and you get reamed by the 'long arm' of the law.
Not to mention weekends you won't drive it, so you can save up some weekdays with that. However...if you drive between 11pm and 1am...I'm guessing this counts as two days?!
The car has to be 25 years old. That's bad
used to be just club events and you had to have all the doco for that, became too hard.
it's now 90 days and you have to fill the book in prior to departing as above no book unrego.
car still has to be RWC.
car has to be more than 25 years old
thee is a very limited number of clubs that you can be a member of and you have to go though them to get it,
not like cams where if you are a member your are automatically eligible.
So if you have an old car you hardly drive then it all good.
but as a rule they make it a pain to discourage you, and you only save a couple hundred a year.
I looked at it for the stang but decided full rego was easier.
I thought club rego meant you can only go to events and stuff not just run down the shops
I used to think so too but then I've seen heaps of cars getting around with em on weekdays. I think it's permits from Vicroads that allow you to visit events only.
130 for a year.. that's about 500
Are club rego transferable to new owner if you're selling a car with one?
No
Oh another
Easier to get mods allowed. That's good.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
