Still scaring the bejebus out of me, but I do push the throttle and RPM a little bit harder with each ride. Thinking of putting a sprocket set on it, as redlining at ~165km/h in 1st gear is not very practical. By the time you're in the engine's happy range (~6000rpm+) you're usually at the speed limit. At that rate I'm not going to last on my option notice. What does 1st take you to on the GSX?
lol, use the footbrake for hillstarts!
not sure what 1st gets me to.. don't really look :D
edit: from the looks of things about 85 ish in this vid:
GT -and- single speed, he posted 2 different bikes :P
lol. that said..
I need 1 x chris king iso 9 speed rear hub.
1 x rear shitmano slx brake,
and a shitmano 105 9spd cassette.
1 xtr short cage rear d.
and i'll be set with my pushy build.
Might sound stupid but I thought that viper alarms weren't ADR complianced?
Correct me if I'm wrong because that's the reason I hadn't bothered to look at Viper
I was under that impression too when I was looking around at alarms but I was talking to the guys at freeway car audio who did the install for me and they said they do comply if you get an all black wiring harness. Which they could order.
lol. that said..
I just picked up an Iron Horse Warrior frame and brand new $25 headset for $3 on ebay, going to build a single speed MTB
singlespeeds are too impractical, can't pedal hop with 26/12, can't go anywhere properly with 26/18.
Nice, nice!
Steamed of fried?
ONLY FRIED
i know this place in preston.....
I figure if I'm cycling with my gf I won't need many gears
and it's for pimpin', got the felt for regular riding
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
