Martin that's a good point >.<
Cass your cars a 4x4 lol, lower it and watch the wheels tuck.
It's a 4x4 because it has massive front pipes...its only at that height that we managed to clear a major defect. Got done this time last year for height (70 mm clearance). Cost me 390 dollars ish to clear it. Left it to avoid further headf**ks from TMU. Will lower it again once I have the money to heat protect and tuck exhaust...but will do for now. Tucked at rears at 70mm, couldn't fit a finger between wheel and guard.
passenger door sound-deaded inside and outside, sound diffuser fitted and new splits installed woo~
Took about a month to do on/off weekends due to weather and other commitments
Drove around with no door skin for a month
Dont think i'll be able to do that with the drivers now ~_~
Especially with the window controls disconnected during this weather lawl
I forsee my sound system to be done by December at this rate haha
fix my rear speakers man! damn alternator whine!
fk yeah ric!.... 57d's are baws!
i wish i still had my orange ones :'(
although i do have a set of the blue/grey ones in 9+22 to use as track rims
Cheers man, I'm hangin for them to arrive, 6-8 weeks apparently :(
Lol'd at this. Can't really bag out on any engines until you've driven a well modded one.
i'd be more than happy to drive a 20det 32....
i just wouldn't bother looking for more than like 230rwkw
Yeah rb20det's are fine
my old 32 was up to 230rwkw on a garrett hiflow BB turbo and spool was good to, not as laggy as you would think
nice man, what sizes?
Cant wait to see them on
what part of your car was ever 70mm? the exhaust?
or are you talking the gap between fender and tyre? ;)
moh, throw inn another rb20... chuck on a 2535 or thereabouts and have ~230rwkw with a nearly 5000 rev powerband.
no engineering, no hastles, no modifications, hella fun and will cost you like $20 for the motor
this man knows what he is talking about.
rb20 - $500
hks2530 or 2535 - $700
Sard Injectors - $600
z32 afm - $150?
nistune - $300?
Tune - $200?
exhaust - $800~
boost controller - $50
$3k incl new engine for 225kw
yup, (although your prices with the "?" need to be doubled) and 230 is actually a pretty fkn quick car.
it's also a perfect ammount of power to be able to carelessly slide without having the troubles of an underpowered car, or trying to wrangle a wild bull
havent kept up with the going rates for car parts these days haha
I remember i picked up gtr injectors + z32 afm for $300 total
Just need to find someone desp for a sale.
Although wouldnt recommend gtr injectors as they leaked 1yr afterwards. Less headaches buying new and never worrying.
on another note; petrol claim for using car for business use is awesome!
75cents per km. Rack up 400km (city and back for a week) = $300 = Final inspection detail due to the cardboard box which hit my car when driving for business >_<
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
