Even in meisters? They will look like 15s lol
they will be fine IF fitted.... 17's are the minimun though
lol what's he saying?
I was thinking more along the lines of police attention...the bigger you are the more you get noticed. It's a shame because seeing pictures like these reminds me of the good old days, and good to import spirit alive and well...won't be long before the police make their mark on them though.
this
17 meisters would look tiny cos of the design spoke not going to the edge, however IF it's low enough & wide enough could work but it's a big call
many 17" meisters dont have the bolts for that reason
I think I'm about to put myself through some serious enlightenment...
My new super-hot chilli's I've had grown... Mixed with my Tandoori Chicken... I suspect with 5 chilli's added in, I'm gonna be floating on some epic endorphins shortly :D
Mate, you're gonna have an asshole like the japanese flag.
Nope, that's the bloke across my house, snob bloke thou.
pretty sure I saw him on my lunch break, i was driving down blackburn road and i saw him move through traffic and i slowed down a bit to get next to him and wave, but he no look and then go infront of me and turn down near your place, i have to say that white r33 needs a MAJOR wash!
Yeah... This 33 looks abandoned at first glance but it's actually a daily driver.
Tall-ish bloke look chunky and wears either some sort of uniform or casual clothing behind the wheel yeah?
Nah, WORK Meisters S1 look good, Aarons just trolling gay.
Nah I'm actually not a fan of them. Or maybe because mines flush and no poke.. I dunno I just don't like the silver on black theme
Unfortunately not.
It was hot... But not UBER hot like i was expecting.
Will use 7-8 chilli's next time. That'll sort it out i reckon.
I'm a chilli nut :)
We have bets with the Thai people when we go to Thailand, that they can't make it hot enough.
One time I felt like I was floating 3ft above my seat... That was a good dish. Took me about 7 drinks to aid the process lol.
The chilli's I have i got from a Turk @ work last year, plant spews out Chilli by the bag full each 2 weeks. It's crazy, and most of them are pretty hot by my stanard (when using 5+, they are a 6-7 on my scale). Although some of them aren't as bad as others so its not a totally consistent plant but good enough :D
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
