those are the rendering from the jeweler, so if it don't we don't pay.
hell he would not even take a deposit.
but yeah we were looking fro a very simple solitaire so makes it easy, tho means was harder to find right stone.
I spent a little more, 5-10% to go though a jeweler, only as they have a guarantee, ie when it arrives if I'm unhappy with it I can decline it.
as for tiffanies, the one we wanted there was close to 30K.....said jeweler is doing same setting in platinum for around 1/3 the price.
thats a huge price difference, was the stone same quality & size?
tony looks nice man.
this is the one we saw that was $18k
http://www.tiffany.com.au/Engagement/Item.aspx?GroupSKU=GRP10001#f+0/0/0/0/0/0
that's crazy saving, good job brah guessing its a sizeable diamond if it was almost 30k @ tiffanys! thats like 1.5-2ct territory isn't it?
pays to shop around with such big ticket items.
Edited by alr33x
Nice Alex, but yeah wouldn't pay that at Tiffany's LOL
In regards to the quality of diamonds, the cut is the most important. This determines the brightness or amount of light reflected back in a diamond.
In regards to colour G/H/I I doubt you'd be able to tell the difference to a D/E/F. As with clarity si2 or vs2 should be sufficient. As long as the inclusions are not visible to the naked eye.
A 1 carat, IF, D colour would be say $15,000
A 1 carat, Si2, H colour would be say $6,000
And to the general public under a naked eye you wouldn't be able to tell the difference
That doesn't sound right man like I said 18k was what we got quoted forget specs might have been an E for 18k haven't seen any 1cts for $30k
A 1 carat, D, IF, excellent cut diamond could easily cost $30-50k plus
All depends on the specs
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
