Pedders 'extreme xa coilovers'
it was either that or teins, but teins are $2500 for fords because shock is separate to spring on the rear. (pedders 1750)
Alex find me some ballin' rims!
19or20 x 9 +20ish
19or20 x10 +38ish
they're the flush / slightly agressive sizes for mine
you could go 9.5 rear with a lower offset as well
Got a small cyst that's grown a little over the years, thought it time to get checked out. Sebaceous baby.
Oh good. I had one of those on my wrist for a little while, hurt when I bumped it. Then it was gone one day all by itself.
are toyota 114.3 though?
yeah don't mind ordering newies just need to find some good ones at a half decent price
some toyota are. the poopra, the snorer are 5 x 114.3
but my mr-s is 4 x 100. weird hey? why? the past mr2s were 5 x 114.3 too.
~7km of bliss, I almost know it like the back of my hand. Poor residents have to listen to my R1 on song during the straights ^_^
I really should get down to Phillip Island...
I watched friends go off there back in the day. Not a particularly forgiving road. Nice drive though. I love Ridge Road (the road between Kalorama and Olinda that Skyhigh sits on.)
I wouldn't want poop on my rims though, that and newb gutterash so might be going newies next set probably be after tune :D
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
