on a positive displacement supercharger (mine) sits on top of the engine, intercoolers not required at first but when boosting up (or spinning faster if you like, generating more boost) you can upgrade to a water to air intercooler, its like a piece of meat in a sandwich and has water lines that go from the supercharger to a cooler (or radiator) at the front of the car.
centrifugal superchargers act more like a turbo, more laggy and air to air intercooler same thing as a turbo
I think you made them cry and they going to shut it down now..
so was it one of you who got banned?
lol just checked
I got banned
over a comment of 'Shhh no tears only dreams now'
Talk about over reaction
Yeah something like, "What's a good looking 18" wheel?"
It's like, OP chooses a wheel they like, they get haters, hating on them.
So when OP asks, what wheels do you like or look good? Haters say, make up your own mind, it's your car.
which is what everyone here is guilty of too
Not needed cause the intake charge doesn't get hot enough to see significant gains and the roots style blowers sit atop the engine anyway, directly feeding the intake manifold, so there's no real room. But people have run them before on centrifugal supercharger setups.
I see.
I have seen some Supercharger kits with a small cooler, so just wanted to clarify.
Thanks for that :thumbsup:
lol just checked
I got banned
Make a new account and call it Linda :laugh:
I don't recall any banning though.
And what wheels you decided on your R32 now?
Take it to Tyrepower North Melbourne, they should help you out.
That was the place I called. The dude with the accent told me that 205 was too much stretch. LOL.
I'll be buying tyres online anyways. Then getting them fitted anywhere.
Lol that's enough jimmy rustling for now
Didn't really do anything wrong though apart from that light hearted humour. How are they to know Im not a hot babez
It's ok for members to give people shit for their rims but its not ok to defend them
Taleb tyres, they got me all four invo for like $900, surely a set of four would cost you what? $300 max?
they can obviously tell you dont put out.
secret
Secret fake ass wheels :laugh:
Try Tyrepower Hawthorn..?
I understood what you were saying, I don't get them.
Yeah, I know :)
Ehy... Forum politics and hierarchy, don't worry about it :)
Lol that's exactly what I though. And that's what I said to the "andystile" mod and he didn't know what to say after that and he took the warn off lol
Those were the guys I was talking about. Already called them. Might just settle with taleb. Haha. Or oxer with his nankangs.
2 different places :)
And yes, Oxer can help ya's out!
you have seen my 205's they fine on 8s
dunno what those guys talking about
Jamie intercooler is the thing you generally do after a tune on my car, makes the power more efficiently on less boost and apaprently after a tune if you have a few runs on a hot day you notice a little bit of power loss a water to air intercooler drops around 30 degrees i think, similar to a side mount vs front mount on a skyline i suppose
any cruises on the weekend? or any plans guyz??
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
