Lol so I've bought a gtx3071r and estimating around 300rwkw. I probably will kill myself, but I don't think it will too as responsive as yours with 300kw for say. Should be fun
definately not considering a 3071 .86 is less responsive than mine on a 2.5 anyway let alone a 2.0 ;)
Yeh going on with a .82 to begin with because it's there. But might go .63 if it isnt responsive enough
stock 26 + n1s and a tune?
26 isn't that good man...I drove one the other day with the same power as my 25, it wasn't any less laggy getting on boost. Left me disappoint after high expectations. Whatever cool, original shit you want to do with your car engine wise...it's all been done before. People have put 1JZs in Skylines lol. Just do the most practical and cheapest thing that most people do and junk a 25 in there.
26 isn't that good man...I drove one the other day with the same power as my 25, it wasn't any less laggy getting on boost. Left me disappoint. Whatever cool, original shit you want to do with your car engine wise...it's all been done before. People have put 1JZs in Skylines lol. Just do the most practical and cheapest thing that most people do and junk a 25 in there.
A 25 neo would be good will have some transient response with the variable timing too!
this.
Anything wrong with buying a 2nd hand bike jacket assuming it's in near new condition? Let's say rrp is ~$1k and I can get it for less than half price
Or for the same price get something not as good but brand new?
/bikes
Couldnt see a problem with it as long as it fits and is in good condition
What jacket is it?
Oh then what's the diff between neo and 33 liner?
Just get a 25 moh out of all people I don't think YOU would notice the difference in 100cc lol
R34 turbo has a bigger rear housing and something else ECU related I think.
/bikes
Nah that's fine, it's not like buying second hand helmets. If it fits go for it.
/bikes
oh thank god. i was starting to think this forums was about skylines.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
