lol I sprayed acryllic primer on my car when I was respraying it, on the advice of the f**ker at the paint place. Took it to the panel shop who told me it needed two pack specific primer on it. This is after I spent hours sanding it all back beautifully (smoother than Moh's gf's young supple skin) :(
Did you decide on colour?
BL0 Greyish blue pearl
-_-
picking up one of these next week.
my ass JUSSTTTT fits in it.
Should get the ark design sparcos! Once you sit in them you'll be in love dude and they are pretty cheap!! I've got em in mine
http://www.arkdesign-au.com/index.php?main_page=product_info&cPath=22&products_id=299
link?
Everyone that sat in mine hasn't said one bad thing.. All of them love it! Wouldn't suit the skinny dream boats though lol
http://www.arkdesign...products_id=299
Will need to sit in your car next time, see what all the fuss is about :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
