I'm just taking the logical approach and hoping for a big refund
We shall see come Thursday :P
f*cking hecs, got my statement in the mail couple days ago. $30,000 repayment still to go -__-
Suck it up Patricia, cheapest loan you'll ever get
Also mine is bigger
Got some big HECS debt on here
Yeah I think I read 2015 (but then who knows when actually available for us to purchase). All good, will be well and truly off my P's then + wait some time for someone else to buy it new and then buy second hand (unless I'm ballin' then and has $$). :D. Apparently priced around $60K (So similar to 370Z $). S16 anyone? :P
Apparently they won't be releasing a new Silvia, more likely a smaller engined Z-car to sit under the current 370Z in the line-up.
2011 and newer polo GTI have the 1.4TC and 7spd DSG.
basiclly deciding between the 86 and the gti atm.
lol I am in exactly the same predicament at the moment, except Golf GTI rather than Polo GTI. I'm leaning more towards the Golf GTI than then 86.
Adam, one is a ninja 250r (very newbie like 500kms under his belt) the other is a r1 fairly experienced / daily
Oh count me in, but only if it's cool me tagging along. Don't want to be a third wheel...get it...
Where you headed?
Wastelanders - this is my first year of house ownership, I'm assuming there's no tax benefits I can claim? I just wasn't sure, I do my own tax every year but want to make sure I'm not missing anything.
Not when it's principle place if it's rented or has been you could I think Toby will know best!
How's it going with the house?
Lol oh well.
At least its reducing your HECS debt :P
HECS would have been paid off at the end of the year anyway :( Now the money I've saved to install ducted heating is all going to the tax man... time to buy some blankets
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
