Lol you know you need a faster car when you struggling to overtake a lady :P
I do not condone speeding, stay safe brahs
It needs some love :-( Twas at 120 KMs... So in an auto.. Twas struggling to get any faster quickly... The 4 speed is shit in that thing... but I'm stuck with it cause of auto Ps :-(... Soon... in 2014... like a big title movie... THINGS SHALL BE DONE TO THAT CAR... And it'll be fun doing them :-)
I remember going up to shepparton, birds saw this.
Alvin was overtaking some bogan in an old xr8, the dude stepped on it and we almost hit an oncoming car (car swerved into emergency lane)
This was in the soarer, and the soarer was missfiring because his pod fell off... LOL
That guy was a flamin mongrel. Goes slow and then when Alvin wants to overtake him he plants the throttle to try and block him out / push him into an oncoming car...honestly surprised you guys survived that, I was crapping myself watching it unfold from behind.
Were you at the SE macca's pre meet? Just curious if I met you
Did you guys threaten to stab him?
i raise you with
"Preview of an upcoming set; This S14a is being built to destroy the quarter mile"
O rly?
Cruises and people being dickheads go hand and hand even on 'official' sau member only cruises seen plenty of speeding and people been pulled over
It happens if you go to a cruise expecting otherwise ya dreaming!
O rly?
lol i said to him "i would like to see what it does on the 1/4" apparently that means its being built to 'destroy' it lol
Edited by Sunkist
Bricks were shat on my behalf...
Wasn't the flamin mongrel on the phone too when you passed him?
Happy EOFY
Stay sharp Aaron, you could win a Merc today
Yeh lol they don't exactly celebrate eofy here seeing as we have it twice a year. Germany has their eofy at the end of the calendar year
Having already done a tax calc and found out I'm screwed, I will completely ignore tax time til October :P
what tax calculator did you use?
need to calculate mine to see if a tax return can help me get to Japan...
btw anyone here does accounting/tax?
what will I be looking at to have a tax agent do my return?
been doing it online for the past few years as i was only working part time
Unaware
Lol
My body is ready.
Depends where you go & whats in it. H&R block or your local accountant would be ~$100. Your specialised Tax Account in the CBD would be any from $200-$500+.
Edit: If you want me to do your tax, send me a PM, I'm doing it for a few guys on Wastelands at a lower price.
Edited by blah_blah
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
