I remember going up to shepparton, birds saw this.
Alvin was overtaking some bogan in an old xr8, the dude stepped on it and we almost hit an oncoming car (car swerved into emergency lane)
This was in the soarer, and the soarer was missfiring because his pod fell off... LOL
I think I can beat that. Two DECAs ago in the Cube I overtook a tow truck carrying a car up to Winton, guy towing a box trailer with a Statesman attempted to do the same. This happened:
I've never seen something so scary as someone out of control at over 100kmp/h and knowing they were headed straight for trees. Both people survived by some miracle. The car was the full bonnet length shorter and the engine went through the firewall.
Anyone know what's involved in declaring the tax free threshold?
Is it as simple as calling my payroll person and telling them to change it or do I have to fill out forms n shit?
Couldn't claim it when I started in November as I was still employed in my old job, but now that I'm not I wanna change it...Tony said to wait til EOFY to do it though..
Didn't quite say that, just said because you didn't quite know you tax position might be safe to just go with a big tax refund
Just let you payroll officer know, it's just a tick of a box
Tax on your mind that much Dezz lol?
pwaa, dat S15! I was going to go to the jdmst meet but no one could take me :ermm:
If you missed out on the JDM meet today come to the Vic Imports meet tomorrow. From what I'm hearing it's going to be pretty big
wooaa I just sus'd it outt, looks like its gonna be huge :O I'm uber keen!
Just smsd you. Can meet at ftg / spring intersection if going monash?
Still going to the SE pre meet in Mitcham though. Was just curious if you wanted a premeet before the premeet haha
And Jdm Kid come along and say hello. We're normally a friendly bunch
Yeah sounds good. See you at the se pre meet
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
