Think the only difference between the plus and pro glove is the hard cover on the wrist strap...Dude at Peter Stevens told me not to bother with them over the Plus..
And the Pro is $250 like the Dainese Joust....
I said I want all that, not that I can afford it.
Peter Stevens' staff are crap. hard cover on wrist = extra protection and it'll match the cover on the shoulders kthx
Will do you a good deal on the plus ;)
what colour are they?
I recommend RST gloves, way more affordable than Dainese or AStars, great quality and fit a billion times better imo. UOf course this depends on your hand shape but I find any other gloves makes my thumb to forefinger movement quite restricted. They also look sick and match other gear well.
Srsly though just get something good quality that fits well, no one is going to notice if your fashion is out of line :S
i want matching fkn gloves!
It only arrived last night. Getting rid of the Daytona tonight so that I can have the excuse to ride it tomorrow huhu
you have a daytona 675?
As a fellow Tein SS user, I'm waiting for you to be my BC comparison/test mule.
But I'm guessing it's the vice versa for you...
Squeak is getting pretty bad, I may have to fold soon.
Surely someone around here has them in an r33... anyone? To be honest I'm more likely to buy those blitz ones, for the jdm respect yo
Have heard good things about them from R33 owners, but I wanted to hear from someone who had SS beforehand. If they are any stiffer I'd rather rebuild the Teins.
BC BR are good for the price.
They are in my brothers R33 GTST. I drove it around of months while he was on deployment. Firm, but compliant.
They also did very while on the track when I wound them down.
I've since driven the car while it's been in QLD. Just as good, both on the road and on the track up there.
They are much softer than any cusco / tein japan stuff. Much more compliant than old stock suspension as well.
My Greddy Type-S are basically BC BR as well.
You got hookups for rebuilding? I've heard it is barely worth it. Confirm/deny?
I wouldn't mind going a bit stiffer, if only cos of my wheels now
It's only one coilover that's squeaking, so would be worth it price wise. Bit of a gamble, cause the others could shit themselves too...probably already worn but no visible/audible signs. I have a phone number of a mob down here, who send them to Fulcrum for rebuild...
lol @ all the Vic exec tags on this page.
Ah ok, let me know if/when you get prices. Mine are knocking a bit, not sure if I should just bin them or go new
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
